MikeG.
This is a very recent project, and is my first experiment at posting images on this forum...........fingers crossed!!
The sycamore was from a huge tree I cut myself then had planked, before I stacked it in the normal way about 7 or 8 years ago. Unfortunately, this isn't the way to deal with sycamore, which apparently should be stacked vertically........Result: I threw away two thirds of the tree as rotten, and didn't have high hopes for the rest. It was covered in white fungus and black mould. I just put it in the back of my garage and forgot about it for 3 or 4 years........
......then had a little play. I was thrilled with what I found, and made this really simple box to show off the wood.
It is finished with Rustins Plastic Coating, because the wood is so soft and porous that my normal waxes and oils were useless. The wood is in parts softer than balsa, and just so damned difficult to work! It had to be soaked in sanding sealer at virtually every phase......even to cut the tenons!
It is the first time I have ever made a piece of furniture with contrasting timbers, and I thought the walnut hinges looked OK with the sycamore. Hope you like it.
Mike
Mike
