Spalted Sycamore and Corian Box
jasonB
26 Nov 2004
Surrey
I have had the design of this box in the back of my head for some time, although I had planned to use a veneered top. The idea of using Corian came to mind when Good Woodworking were doing their competition for an item incorporating manmade materials but lack of spare time prevented me from getting the box made in time for the deadline.
The lid extends behind the pivot point and acts as a stop when the lid is open
As you can see the Corian was tapered from back to front by suspending it in a sloping jig above the router table.
Once the machining marks from the tapering process were sanded out the piece of corian was thermo formed by placing in an oven for 15mins at 170degC. It was then slipped into the vac press and bent to the former before it cooled down too much. The layer of cardboard is to protect the vac bag from the hot Corian. It was a bit of a job to get it all in the bag and lined up while wearing thick gloves!
As I want to make a few of these boxes, the former for the curve is a bit oversize so I can make longer boxes and I made a simple jig for the mortices. Tennons & grooves for the veneered ply base were all done on the router table.
Corian is finished with Micromesh, sycamore with Mylands celulose sanding sealer & wax, inside base is self adhesive black baise.
Hope you like it, any comments or questions welcome.
Jason
That's very nice Jason! Is it for holding something in particular? What's Micromesh? ('scuse my hignorance!) :)
Thanks for the comments guys
It's not made for anything special, measures 9"x7" so could be used as a jewelry or pencil box.
Micro mesh is a system of very fine abrasives that was originally made to polish the scratches out of aircraft windows but works on most plastics. You can buy small kits with all the bits.
Jason
Jason
Very nice indeed, would never have thought of using corian for the lid. How time consuming was it to pouter the lid to shape before the forming?
Also how long did it take for the whole project?
About 15mins routing, 15mins knocking up the jig and a few hours thinking of the best way to to it beforehand.
Took about 3 Sunday mornings if you don't count felling the sycamore, waiting for it to spalt, planking and drying :D
Jason
Very nice Jason and a really interesting combination of materials. I've not worked with Corian but it looks great. Do you wait for offcuts from your kitchens or do you buy it in sheet form? I've no idea where or how it is bought.
Are the hinge pins sycamore as well?
Tim
I'm quite friendly with the Corian fabricator that I use for kitchens & bathrooms, he lets me have what I want from his offcuts pile. It comes about 700x3600x12mm thick but can be bought in 1/4, 1/3 & 1/2 sheets. Some colours also come 6 & 18mm thick.
Hinge pins are 1/8" brass rod.
Jason
Very nice,Jason (as usual!)
Also impressed with the quality/layout of the photos - ever thought about compiling a book ?
Thanks PT, I think it would need several volumes, have you seen all my albums, just too many interests and not enough time :wink:
Jason
Yes,I've seen quite a few of your photos on different threads on this and other forums - still think the chess table is a masterpiece!
It's seeing that standard of work that makes me spend my spare time on forums like this,to be able to learn more,and aspire to achieving work of the same quality (inspiration and practice,that's all I need.. :wink: )
Andrew (also never enough time for all the things I plan to do :? )
Excellent, a really nice piece once again.
Adam
Nice one, Jason.
The corian is certainly eye-catching, but the proportions and design of the box work really well also.
What is the joinery between the front/back and the side pieces?
John, The springback was minimal maybe only 1mm, the sides were shaped and height of front & back finalised after the corian was bent.
Chris, I think that gentle compound curves may be possible but too tight and the excess would buckle around the edges. Not sure how the corian basins are made but I don't think it is from a flat sheet, will ask my Corian man when I see him next week.
Pete, One of the pics shows all the parts with their mortices and tennons.
Jason
