You hit the nail on the head, that's precisely why I have been getting more and more tempted to change to the Sorby.
I have the Tormek jigs, but I never did like the actual Tormek grinder much, I bought the Worksharp 3000 and it's utterly fantastic for small carving tools and bench chisels of all kinds (what I originally bought it for before taking up turning), but it's very lightweight for heavy stock removal and I struggled for ages with trying to reshape my large bowl gouge on it, I eventually gave up when it wore out it's second 60 grit "Long-Life" paper without getting anywhere near sorted on the gouge. Either the HSS in this particular case is made with Kryptonite, or the small motor and the rather tiny working area just can't cope (it's only 6" sandpaper disks, and you're aimed at a single quadrant in use)
I'd originally been put off the Pro Edge due to it's slightly fiddly belt changing in comparison, but with some experience under my belt now, I realise how seldom I'd actually change between belts for the turning tools - I don't aim for a nice surgical gleam like I do for my fine bench chisels, just a 240 grit touch-up 90% of the time, and a coarser reshape when they wear down.
Finances are not as tight as they used to be either, so I'm tempted to save and just swap. If the Pro-Edge can do justice on the finer sharpening front for my bench chisels, I may even sell the Worksharp and keep the Pro-Edge as my only grinder/sharpener.
Thanks for the advice.
Nic.
