Doug71
What are you using for dust extraction on yours Mike? I have a KS60. Among the many reasons for getting it was the supposed better dust extraction. With the 27mm Festool hose on a CTL MIDI I've been really underwhelmed by the extraction. Using a 36mm hose improves the situation but it still isn't amazing.
I had planned to build one of those boxes around it, but I'm convinced most of the escaped dust travels around 45 degrees up and to the side, which would just bounce of the front of any shroud.
I have the KS 120 and find the dust extraction very good compared to other saws, not sure if the KS 60 is the same .
On the KS 120 cutting technique makes a big difference to the extraction. You need to first pull the blade towards you past the timber then drop it down and make the cut pushing the blade away from you. Sorry if I'm telling you something you already know but on the KS 120 if you just use it like a chop saw pushing the head straight down to make the cut a lot of the dust doesn't get collected.
Once you start cutting mitres, bevels and compound mitres the dust collection does get a bit more random!
