CHJ
A taller vase was mentioned as a requirement by someone who must be obeyed, if this was to be constructed with minimal sections this meant that a set of staves long enough needed cutting on the bandsaw.
The resultant cleanup of adjoining surfaces and reasonable glue up lead to a rather short lived burst of euphoria when the realisation that holding the said assembly for safe machining was not going to be straightforward with existing chuck jaws etc.
Driving the piece for initial cleanup was achieved by using 4 long studs in the Cole jaws , (can't use 8 studs on a 12 section cylinder if it's to run as true as possible) but the matter of supporting and centralising at the tailstock end needed the construction of a spreader adaptor to use with the rotating tailstock.
This allows the centralising of the piece at the tailstock end and provides secure pressure against the driving chuck.
Rough truing of the blank and subsequent forming of a tenon to enable mounting of the blank on a standard chuck for improved concentricity control and secure holding for hollowing.
