Risky Duckfeet
As above, I've got a slide saw and guessing that that is the easiest way to cut the joint but in case anyone knows better I thought I'd ask. I'm a bit worried that the saw will not be accurate enough.
I've asked somewhere else and had some good answers but the most recent comment was; "There are obviously quicker methods but you need a good knowledge of machinery and a higher skill level than being able to use a sliding saw for those methods................dado cutters, wobble blades etc." Don't know if it was supposed to sound like that........
So what I really want to know is :- If 400 of these joints were being cut to order to make a cabin or similar, how would they be done.
- If I wanted an efficient way of cutting around 400 of these joints, assuming that I have a reasonable level of skill, how would I go about it?
Many thanks for any good advice that I may receive.
