I'm currently building a Rob Cosman workbench, one of the additions he has made is to add a solid wood edgebanding to protect the mdf edges.
He uses torrefied wood to eliminate and movement and glues it directly to the mdf edges.
The top is made up of 3 1 inch layers of mdf glued together.
I have some sapele that's 100mm wide and 20mm thick, however as it's not stabalised I'm concerned with it moving and causing issues with the top.
Would glueing the edgebanding to only the top most layer of mdf, be sufficient and prevent any issues futher down the line?
Attached an image of the mdf top, note the top is currently upside down, hence the holes.
Thanks.
Thanks.
