tsb
I'm in the middle of making a drawer unit, which will have 3 drawers in it. The drawers will be drawer boxes, with a false front screwed on made of solid oak. The height (as you look at them) of each front will be approx 10". I think I will need to joint the oak to stop potential problems of movement etc, but what is the maximum width you should use as a solid "plank". ie is 10" too wide a piece to use or would you use two 5" pieces joined with biscuits
