SOLD
Never really got on with this (drilling the holes mostly) and went with a router jig instead. It's the original MKI set. "Someone" (homer) tried drilling through one of the 3mm holes (see pics) and killed the original drill bit. Said hole is now just slightly oversized and has just a hair more play in it. The other holes all remain unscathed
It has a new drill bit (still one of the original iterations) but with a new split shaft collar that stays in place unlike the original made-of-cheese one (also included). Oh, and I'll throw in the 2 stainless parf dogs you need as well.
A MKI set sold on here for £75 just recently so I'm asking for £50 due to the dodgy 3mm hole in one of the rulers. Axminster will sell you a brand new one for £25 here.
It's all been kept indoors and only used to make one MFT top.
Included is the full set plus a couple of extra bits:
2 rulers in protective sleeves
3 x 3mm locating pins
3mm guide bush
3mm drill bit
20mm drill bit
2 x 20mm drill bit depth stop collars + hex key
2 x stainless steel Parf Dogs
1 x guide bush thing (the orange thing in the photos)
P&P is on top, but most likely around £10 via Parcel Force and shipped in the original tube packaging.
NOW SOLD
3mm guide bush
3mm drill bit
20mm drill bit
NOW SOLD
