Sawdust=manglitter
NAKAHASHI JAPANESE MORTISE CHISELS & BIT - 10mm, 12mm & 16mm
Brand new mortice chisels and bits by Nakahashi. Sold by Scott+Sargeant. Bumf from their website...
“These mortise chisels are manufactured to the highest standards from the best quality steel in Japan. We have found they out perform all others we have tested.
The auger bit on this type has a point with one cutting spur and a single spiral for efficient chip clearance. The single spur is easy to sharpen and the bits cut evenly and fast, even in the hardwoods. The heat treated chisel body itself is hardened and precision finished by hand with a sharper cutting angle than the traditional English pattern for reduced effort.
N.B. The augers are supplied over length to accommodate different machines and may need cutting with a hacksaw to suit your particular machine.”
There’s more info here...
https://www.scosarg.com/leaflets/Nakaha ... atalog.pdf
13/16” shank to all three sizes
10mm mortice chisel and bit - £50 including postage (to UK mainland)
12mm mortice chisel and bit - £55 including postage (to UK mainland)
16mm mortice chisel and bit - £65 including postage (to UK mainland)
ALL SOLD
All three sizes for £160 including postage (to UK mainland)
ALL SOLD
