SOLD- For Sale
BOSCH GCM 12 GDL Professional Mitre Saw
£450.00
https://www.bosch-professional.com/mz/e ... 0601B23600
Now I have a table saw this gets very little use and I need the space. I bought it because it is possible to install right up to to a wall, the glide system only moves forward, there is no element sliding back behind the saw. The use has only been for hobby work (I am not a tradesman).
The specs:
52 deg left to 60 deg right
Saw Blade 305mm with 30mm bore
Bevel cutting 47 deg L&R
2Kw motor (3800 rpm) soft start
Cuts up to 104mm x 341mm
Mitre Cuts 45 deg 104mm x 240mm
Bevel Cuts 45 deg 51mm x 341mm
There is supposed to be a LASER however, I can see the red light but it is not strong enough to be seen on the saw bed.
£450.00
The specs:
