• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
For Sale SOLD-Axminster 1/2" 240 volt heavy duty Router
woodman2
24 Nov 2010
Devizes, Wilts
Axminster "White" 1/2" 240 volt 1650 watt router. Variable speed. Will also take 1/4" collet (not supplied) Used for one kitchen fitting job only so very much as new. All accessories included but one catch on the case broken. Rather heavy so collection advised. £95.00p
For what it's worth, I've got one of these and was impressed, yes it's an older model, but that's also good because it was made when Axminster was a brand that was worth something instead of the chinglish imported rubbish now.
I bought mine second hand also basically unused, brushes are a standard size so easy to replace and the collet has essentially zero "run out" that can be measured with a dial test indicator.
Oh it's also a true 1/2" not 12mm as often seems to be the case now, so 1/2" router bits won't slip.
Isn't it a DeWalt copy?
I have a similar one goo machine need to put it under a table really.
