sitefive":2eh1bi62 said:
P/T is probably one of the biggest purchases you will have if you are just starting out,
From what I understand all of the units does the same job (the super cheap ones and expensive ones) however the main differences is in the Noise levels you get and how sturdy they are
That statement is just plain wrong, and if you base a buying decision on that assumption then you may well make an expensive mistake.
What I generally see in hobbyists workshops is a P/T that's way, way overdue for a blade sharpen...often to the point where the machine barely functions. More expensive P/T machines often have accurate quick change knife systems, either Tersa or some other proprietary method. If you can stretch to it then it's worth thinking about, because a P/T with blunt knives is just an expensive shelf for your coffee. IMO your biggest priority when choosing a P/T should be figuring out how you intend to keep your knives in tip top condition, either quick change or really getting on top of the traditional sharpening/setting procedure, and clearly understanding if any particular machine will be a help or a hindrance in that respect.
In addition the more expensive machines will have counterweights/springs on the tables, much higher levels of built in accuracy, more comprehensive table adjustments, better gauges for monitoring cut thickness, multiple feed speed controls, better anti-snipe rollers, the ability to adjust thickness in very small increments without leaving feed roller tracks on the workpiece, better extraction, etc, etc.
I've seen dozens of P/T machines in operation and there's little correlation between price and noise once you get beyond the brush motor/induction motor question.
