MikeW
Well, I made a new handle for my Disston D-8 this weekend. Unfortunately one must make sure to pick the proper bit when cutting holes for the saw nuts.
In these messy pics (the mess is the bench <g>), one can spot three different bits. Those were the proper bits. For whatever reason, I picked up a fourth one that I had out when seeing what sizes I needed and didn't put back the wrong-sized one.
Went and drilled the wrong size for the back saw nuts. Oops. So, when I recover from this--a D-8 handle takes a bit of work--I'll remake it. Chalk it up to live and learn.
The main notable thing about a D-8 handle is the kerf in the handle to receive the saw blade needs to match the radius (7") of the end of the blade. And there are actually two different cuts to make as can be made out in the last picture.
This is the main reason that it is difficult. That and it is a closed top, meaning the slot does not come up through the top of the handle. I took a lot of care and did pretty good. Though I did pare off the tip of the handle and a little of the slot can be seen in the first picture.
But it was a fun experience, and the blade is cleaned and the teeth have been touched up. I'll use this handle as a pattern for the new one. The original was missing the entire bottom portion, so now I have a full pattern.
Mike
Mike
