Mittlefehldt
Finally after a month of waiting, it was a month late coming, I went to my local Lee Valley store last Saturday, and purchased the Veritas small plow plane.
When I got it home I read through the instructions, well actually skimmed them, and then went out to the shop to play, er I mean test it out.
The fit and finish seems excellent including the very very sharp blades out of the box. Everything worked as it was supposed to, I tried white pine and white ash, good results both times.
Overall it is what it purports to be, and I only have two minor quibbles. the first is the hand hold on the fence is a tad small, and in the same vien the knurled knob for changing the blades is a tad hard to get at again because of the small space inside the fence, particularily when it is tight and therefore hard to undo. Well not hard just a bit less than easy. As I said minor quibbles.
An excellent tool and I hope to get much use from it. If things work out I will post pictures tomorrow.
