AndyT":1okh3cc4 said:
Lorries, camper vans and boats have used diesel heaters from Webasto or Eberspacher for many years.
Cheap Chinese copies are now getting attention from people whose eyes light up at the big difference in price.
Discussion often focuses on the risks associated with diy installation of a bare unit, where the user has to successfully find a way to fit the heater so it's safe. That means fixing it to something permanent where it can't be dislodged accidentally, providing safe storage and delivery of fuel and routing a dangerously hot exhaust away from dust and combustible material.
Here's one such discussion with a video as well.
https://www.canalworld.net/forums/index ... amps-used/
The evidence I've seem suggests they work and work well.
I am looking at Webasto, Erb......(spelling) as well as the Chinese versions. For me its not about price of the unit but trying to avoid the crippling cost of heating my workshop this past year based on using a large gas tank next to the w/shop.
Most of my work does not slow down much for winter so being able to use glue, stains etc is essential.
I have seen a video of one of these diesel heaters arranged outside the workshop high up on a wooden wall....mine is brick. Input air from workshop/output heat into workshop/ diesel from an external tank close to heater/external exhaust.
Seems to be quite logical.
Comparison with the old paraffin burners which produced water and rusted tools is non-existent.
I have seen a few bits of video which measured the output of particles from diesel exhaust at 12"/300 mm from the end of the exhaust which indicate a very clean burn. That clean burn can be further improved by a high burn rate for 15 minutes and then putting the device into shut down mode.
Negatives which I have gathered seem to be:-
1) Noisy fuel pumps
2) Noise from hot air input to heated space
3) Need to refill the 10 gal diesel container
4) Device can become full of carbon deposits if high burn rate then shutdown is not followed
Costs on a medium setting seem to be about 3 days per litre of diesel.
Positives
1) Its old technology and has been used on lorries, ambulances, RV, etc for many years
2) Lower costs compared to my propane tank and electricity
3) Can be mounted outside
4) Basic items to mount it and route air is provided in the kits.
So any actual experiences of using in a workshop.
Al
