tim
I'm after some small (less than 60mm dia) cable outlets for a couple of bits of built in furniture. Trouble is I can't find a source.
Anyone know of any?
Tim
Anyone know of any?
Tim
Rich":16lkgecd said:Hi Tim, I did'nt know what a cable outlet was so I googled and found 56 of them on ebay, hth
regards, Rich.
JasonB":16lkgecd said:I think the reason most of them are 60mm plus is that is the smallest you can pass a 13amp plugtop through, not needed if its just USB/phone cables.
Ironmongery direct do them at 46mm
Jason
jasonB":32ziv5fj said:The other option is to use the plugs for 35mm hinge holes with a small hole drilled in them to suit your cable diameter with a knife cut to the edge so they can be slipped over the cable.
Doms ones require the cable to be threaded through, used by sky fitters when they blow the plaster off the wall when using the SDS to heavily :wink:
Jason
