twodoctors
Hi all,
I've only just been playing with different finishing products having had less than satisfactory results because of wrong application methods (I think).
With Osmo Oil, I like the simplicity and fairly decent finish it gives (I'm using Stain Clear). However having gone into the website for Osmo, I reaslised that I've been doing it all wrong (and also advised all wrong).
https://www.osmouk.com/sitechapter.cfm? ... 2&page=247
It says it's not compitable for most of the wood I've been putting it on (walnut, sapele, cedar, and sycamore). I should have been using their Wood Wax Finish Extra Thin instead, which is "thinner, so is better absorbed in these oily wood". Does anyone have experience with their extra thin product?
Also how did I make it shiny after 2 coats of Satin Clear? I've tried Chestnut Microcrystalline Wax, but have been having mixed result. I put the stuff on liberally and then wait 20+ minutes and get it buffed with a buffing pad attached to my pillar drill (I know, I'm lazy!). I get some kind of sheen, when I was hoping for a bit of gloss. Should I get the Gloss finish Osmo Oil instead? Or use shellac or TruOil (both of which seemed a bit more work!)?
Thanks.
Adrian
Thanks.
Adrian
