My next project calls for sliding doors, and I'm trying to figure out the best way to make them. One option is to use plastic hardware such as this:
http://www.leevalley.com/US/hardware/page.aspx?cat=3,43614,43620&p=40162
Is that actually a good way to go, or just the easy way?
The all-wood approach involves cutting a groove at the top and bottom, cutting a tongue on the door and having the door move wood-on-wood. I have encountered two different approaches here.
1. Cut the groove in the bottom of the case shallower than the length of the tongue on the door bottom. The wear surface is the bottom of the groove. This seems like the obvious approach.
2. Cut the groove in the bottom of the case deeper than the length of the tongue on the door bottom. The door rides not on the bottom face of the groove but on the case surface in front of the groove. The tongue only serves to align the door and keep it in lateral position. (This method was suggested by Janofsky in a Fine Woodworking article.)
Does anybody have any thoughts on these different alternatives? Which one is best (not easiest) and why? I will be making the case and door frame out of a hard wood that won't wear easily.
