Lonsdale73":169k34dv said:
Never used them before I've just bought some of the above to fit a heavy extractor to breeze block wall. The label on the back suggests drilling a hole 40mm deep, allowing a maximum fixture thickness of 35mm. My fixture is no more than 2mm which would leave the bold some 33mm proud. Can I take it that quoted 40mm is a minimum depth required and I'll not be reducing the effectiveness of the bolt by drilling deeper?
Just a thought, if you can get to the other side of the wall, then drill right through the breeze blocks and bolt the extractor to some angle iron on the other side of the wall running vertically or horizontally overlapping at least four blocks, that may do it, but only if the block laying is good and they are at least 100mm thick, alternatively use the angle iron to make a frame and support the extractor from the floor, another thought, hang the extractor from the roof.
Mike
