Dominik Pierog
Ok I cheated this is cardboard and laser cut.
Project gallery > http://decodrew.deviantart.com/gallery/52787462/Skull
DXF project two types of cross section horizontal and vertical > http://www.cnc.info.pl/download.htm?id=26285&special=68
Project generate on 123D make
https://www.youtube.com/watch?v=jo5TxtKLmjM
But you can use scroll saw, scalpel or different technique.
Material thickness 3mm that could by : plywood, cardboard, pleksiglas, foam, rubber etc.
It's easy and cheap project. Time consuming 1-2 hours for 5 days.
I use wood acrylic filler, water dissolve. After drying I think is waterproof.
60 layers/parts glued in 1 hour.
Add filler
After first sanding
Repeated 6-8 times
I make final coat using wood glue, little filler add, black dye, all dissolved in water.
Paint test
Sanded.
After painting, little sanding, painting and painting again....
Add filler
After first sanding
Repeated 6-8 times
Paint test
Sanded.
