Skirting to Architrave
Jay James
10 Jun 2008
Saffron Walden
Hello there,
Just wondering if someone could give me a bit of advice please, I'm putting new skirting board which is Ogee shaped, in my living room and have come across a problem.
Excuse the drawing, (I've lost my camera cable)
Do I cut the architrave and take the skirting right to the door frame?
Do I take the skirting to the architrave and put a chamfer on the skirting to allow for the 8mm difference?
Or non of the above.
I'm stuck, I've been thinking about what to do, I could do with a fresh set eyes.
Any help or advice would be greatfully appreciated.
Jay
That is what I would do.
Or you could put a square block at the corner, which is thicker than the skirting, and butt the architrave and skirting upto the block. There is probably a technical name for the block, but I don't know it.
Karl
Cant you change the architrave as well , the traditional style skirting is never going to look quite right with that style of architrave, or alternatively get skirting that matches the architrave. Putting a chamfer on the end of the skirting would be one solution, or you could cut the architrave at the height of the skirting and fit a rectangular block the width of the architrave and the thickness of the skirting which will bring all the elements together. Hope this makes sense
How about an extra bit of trim on the door frame to pad it out? I take it you will be repainting it all or such so it could be blended in?
Karl
They are known as skirting blocks and are specifically intended to regulate any deviations between skirting and architrave, so the ideal thing here. Some people do them just for the look of them.
Ed
Wow!
Thanks for the replies chaps. I never thought about doing skirting blocks. Sorted. That's what I shall do.
Many Thanks again. Always good to get a fresh set of eyes/ideas.
Jay
Make the block slightly thicker than the skirting so you get a neat shoulder where one meets the other.
Ed
Jay James":3tua15jj said:
Hello there,
Jay
The common US practice of making a 45 degree miter return and snipping the bottom part to fit the architrave looks very good to me.
"You are going to want to cut a 22.5 degree bevel on the end of the skirting board and glue another piece of skirting board cut with a 22.5 degree bevel going the opposite way. On this piece you will also want a 45 degree bevel going the opposite way of the the 22.5 bevel. Both bevels on this piece need to meet at the short point on the back. This way when you glue it to the other skirting board it will look as though the skirting board just turns back into the wall at a 45 degree angle.
Once you do this you will want to measure the thickness of the architrave on the edge that is going to meet up with the skirting board. Once you have this thickness you can cut the bevel of the skirting board to match that thickness. That way it will look like the skirting board just bevels down and into the edge of the architrave."
Go for plinth blocks as already mentioned, looks smart and solves your problem. I feel anything else just looks like your trying to get over a mistake. I am in the process of doing this myself. :)
This is how I've always got over the problem. (didn't know there was a name for them)
Well I guess its a matter of opinion, but personally I would do them square as in the first picture.
Ed
