Lightweeder":38y8dqdc said:
but what's so marvellous about the skew
When used correctly a skew should give you the best tool finish for most parts of spindle turning. The only exceptions tend to be coves (for me, at least) and anywhere that isn't wide enough to get decent bevel contact.
It lets you get away with starting your sanding at 180 or 240 (or even higher) depending on how good you are.
If you can't manage the skew I'd say don't use a scraper - you should get a better finish using a gouge.
I found that the best way to improve your skew control is to practice on suitable timbers - something that's straight grained without much figure.
You could keep a practice piece next to the lathe and maybe start and finish each session with 5 of 10 minutes at it (although if your times limited that can be tricky).
As others have said - it's easier to start out with a larger skew as it gives you more margin for error.
I've only ever used oval skews so can't comment about differences between them and square edged ones.
Make sure that your toolrest is if free of nicks and bumps - the last thing you want when doing a nice smooth planing cut is your tool jumping when it hits an imperfection. If there are any serious problems you can remove with a file and/or wet and dry.
One thing that can help whilst learning is to use a
Steb centre - it allows you to wind off pressure at the tailstock so that the timber is being driven just by the teeth. If you get a catch then the timber just stops turning rather than the tool jumping into the timber and making a mess.
Also, make sure that the tool is well ground - having lots of facets from dodgy sharpening can make things difficult.
Eventually you (hopefully) will be able to do all your spindle turning with a skew, including the roughing out from square.
Duncan
