SIP 01332 Measures?
andycorleone
15 Aug 2007
Thurrock, Essex
Hi, I've read that the table measures is about 1100mm by 800mm, is this including extension wings and everything? let say that I have a box with a internal space of 1100mm by 800mm and this machine full open can cover this area? many thanks
From a retail site:
Motor Power – 3hp 240volts
Maximum depth of cut @ 45º - 53mm.
Maximum depth of cut @ 90º: - 75mm.
Maximum distance from blade to fence with extension: - 590mm.
Table size without extensions: - 560mm wide x 800mm deep
Table size with extensions: - 1170mm wide x 800mm deep.
Blade diameter: - 254mm.
Bore of Blade: - 25.4mm.
Blade tilt:- 45º to left.
Blade speed: - 3500rpm.
Table height: - 845mm.
Net weight: - 177Kgs.
Gross weight: - 192Kgs.
Warrenty – 2 Years
Dom
The cast iron table is 1170x800 but the fence runner extrusions and the lock handle for the fence give max overall dimensions that would require a box of 1510x1150 the 1510 could be reduced with a hack saw to the fence runner extrusions also the runners can be slid left or right for particular applications but this can upset the measuring tape which is fixed.
