No sub table extraction Martin as this would compromise router lift, instead I have fitted a polycarb shield to the top of the router so that any dust that falls through the table falls onto the shield and from there to the floor.
http://i41.tinypic.com/2u5deg0.jpg
This is not the best pic but it may help, if not I'll take another for you, but basically the fence is two alloy box sections that attach to the saw's fence with a suction pipe down the centre of one to extract the dust.
My TS is the workhorse of my shop, is does just about everything bar make the coffee!
I found with the 'Aldi' type tables that you were working at an uncomfortable height and that the table had a tendency to move whilst machining. With this conversion I have overcome both problems and taken up the minimum of shop space.
Roy.
Roy.
