I really wanted to make one from scratch, but the cost made it a non starter.
I ended up buying a normal second hand shed and altering it just make it a shepherd hut style shed.
It cost as much for the corrugated sheets to be delivered as it did for actual sheets. £150 delivery and £150 ish for the roof.
Part of mine was an experiment to see if a decent shed could be had from a factory made banger. If you're gonna make one you'd have a studwork frame covered in breathable membrane,followed by battens and your outside boarding. The air gap is the key to not getting condensation.
The shed was featheredged, so ventilation was really good between each board. I used the original shed studwork as the outside batten part and stapled the membrane to it. Then built a 2 inch studwork inside of that with celotex insulation. Before I assembled it I put the floor in upside down so I had ventilation in the walls and floor.
A few more pics can be seen in this thread.
viewtopic.php?t=100834
I've a load more somewhere but don't think I did a wip cause it was a bit rough and ready tbh.
All of this was a complete faff ,the only reason for doing it was to save money. Factor in the time i took pi55ing around I'd have been better off working and buying decent materials.
I chose curvy laminated beams for the roof,that along with making the curvy interior roof was probably the hardest part of the build.
I love the look of proper ones with nice cast iron wheels,but for me this knock off version ticks most boxes and hopefully doesn't look like a bog standard shed.
It's nice to sit in there when the wind and rain is smashing around, doesn't take long to get it nice and toasty inside.
If you do decide to make one I'd love to see a few pics of the build.
Coley
