rob.
I stripped the old polish off an antique chest of drawers by dissolving it in methylated spirit, I used fine wire wool soaked in meths then a cloth to remove. This got most if not all of it off. The drawer faces are mahogany.
I didn't sand the wood to try and retain the colour and patina.
I went over it with a fad and some button polish. The result was a crickled effect that looks like frost in the grain when the light catches it.
I thought ''that's not right'' so thinking there might be contamination I stripped it back again using the same method, this time around I put 4 coats of shellac on with a brush allowing it to dry between coats then let dry for 3 or 4 hours. Ive just cut it back with fine wire wool and rubbered it again with button polish and the frost is back.
It looks like light being reflected from within the grain.
Ive begun to polish the carcass of the chest using the same stripping method and its fine.
Any ideas?
Any ideas?
