Sheffield-List Gouge Sweeps
Argus
21 Oct 2002
Ceredigion Uplands
Are there any carvers here?
Other than laboriously creating the circle of each gouge by rotating it on a piece of scrap, how do you work out the diameter of a circle that results from a sweep-arc on the Sheffield List?
Is there a reliable table of actual diameters somewhere?
I’ll explain.
I’m a little old-school in that I was brought up on British gouges; where the sweeps were marked, it corresponded to the Sheffield list. When I have acquired older, unmarked gouges I quickly establish the ‘Sheffied’ sweep. It’s the same with the newer continental Pfiel or Kirschen gouges that have a different progression of sizes and sweeps – they get marked with the nearest ‘Sheffield’ profile.
Lately, I’ve been following some of the Mannerist carvers who carve in the Jacobean style, notably Peter Follansbee who specialises in late 17th C English and New England furniture.
He’s producing some accurate 17th C decorative panels much of which centres on patterns made of vertical stab cuts- here’s an example:
In the main, much of the patterns are laid out with a Vee tool, then the details worked from vertical stab cuts that utilise the entire arc of the gouge to make the elements. The original workers would have worked with what they had….. probably a few basic shapes.
But establishing a selection of working tools for this purpose – using the sweep’s profile instead of its ability to remove material - needs a knowledge of the full diameter of the sweeps on the Sheffield list which is never published.
Hence my question.
If you are trying to work out the radius of the circle of which your gouge is an arc, my usual way is to use what's to hand- paint cans, plates, etc- put your gouge to it, see if it fits.
I would guess that once you have got a few of those, a pattern might emerge?
gouges much like hollows and rounds did follow a pattern and it may be possible to figure this out. but in those days not much was "standard" and as they are sharpened that will also change the sweep.
