Sheet Materials for Benchtop
Jelly
20 Sep 2012
Sheffield
I'm after building a breakdown bench/assembly table to be used and stored outside, However I want to span about 8ft between two oversized trestles, so the stifness of the worktop is a bit of an issue.
I was considering using OSB3 over a latticework of pressure treated carcassing material, but was unsure of how thin I could get away with and still have a solid feeling benchtop.
I'm also unsure if unfaced OSB would make a nice working surface, I'd be intending to cover it with a carpet offcut for assembly work, but would it be worth facing it with thin WBP or Marine ply for heavier duties?
Any input most appreciated.
You might consider an angle-iron frame, talk to your local agricultural engineer.
There was a video for a fantastic self-assembly bench from an American wood worker which broke down into manageable sections but was large and sturdy when assembled. I'll have a look and see if I can find it.
