Corneel":2f05zo41 said:David C":2f05zo41 said:The answer is too obvious, and not relevant to the majority of cabinetmaking sharpening, (chisels and plane blades).
I am not a carver, and have very occasionally used in cannel gouges.
These were sharpened with a flat stone and some slipstones. How else?
David
So you have no trouble with it?
And router planes, molding planes, marking knifes, drawknifes, skewed irons, German scrub planes and everything else. And each one of them is just a little or quite a bit more difficult then chisels and planeblades. Combine that with the freedom aquired with freehand sharpening, the speed and the better use of the stone surface, and you'll have to confess that freehand sharpening is the more rational method.
All the difficulties with freehand honing chisels and plane irons is obviated by simply honing on the grinding angle. The cutter clicks, toe and heel, registration is positive - as positive as using a jig. When the hollow gets a little small, just refresh it. Unless nicked, the grinding wheel should never shorten a cutter. If a burr is being produced at the grinding wheel it's being used incorrectly (except in the case where a nick is being worked out).
Jacob's method works exceptionally well too.
