They look nice, Chems. I might have made the legs slightly thicker or kept them slightly wider at the bottom of the tapers but, it's fine line between having something that looks like too much a taper and a tapered leg that still looks parallel... If that makes sense!
You probably wouldn't want to cut the legs from thicker stock as the current thickness works well with the bevelled edges of the top.
I bought some of the Chestnut hardwax oil from Richard this week and my first impressions are that it's not quite as thick as the Osmo oil, which makes it a bit easier to apply (photos in a couple of days...). It's really great stuff and this kind of finish is more hard-wearing than other oils (Danish, linseed, tung, finishing, etc.). Also, it barely darkens the wood, unlike the others. :wink:
I glued up a 6mm drawer base the other day and this is how I did it:
Very similar to your setup except, I clamped a pair of strips at each end to keep the ends as flat as possible. If you're worried about these sticking, putting a bit of wax on the mating surface. :wink: It's not just Titebond III but, with their other two main glues (I and II), you can also remove the cramps after half an hour (as long as you don't stress the joints!).
I can see why you want to cut those chamfers on the table saw (are you cleaning them up with your plane, afterwards?) but I would make the left-hand guard at least 100mm tall, so there's no way your left hand can get in there! :? If you made it wide enough, you could also have a surface for running a push-stick along, which should keep your hands even further away (though, personally, I'd prefer to do this on a router table first!!
Selling - you could approach any local shops, galleries, or try to get your nose in to any forth-coming exhibitions that might be going on (?). Be aware that most shops will want to add their own 'mark-up' though, which could greatly increase the selling price, even by an extra 50-100%. :?
Pricing - obviously, you need to look seriously at how long these have taken you to make. It's generally "easiest" to look at the number of days - £250 per day (ten-hours). Though, if your overheads are low enough, you might want to get away with charging £20 p/h... But then, what do you do when you move to a larger workshop? Suddenly bump your prices up sharply and frighten all your previous clients away? Another way is to break it down in to processes - how long does it take you to perform each action of the build? Is there anything you could do to make each process faster, more efficient? If you need to reduce your costs, which parts of the design(s) could you alter? If these first two sold quickly, would you look at producing a larger batch, which could also reduce costs slightly?
Do it both ways (counting the number of days and the calculated time spent on each process) and I'll bet the results are different!
Oh, and don't forget to add your material costs (including wastage allowance) on top!
