engineer one
just to ensure that alf does not think i put too many topics in one area!!!!!!!!!! :lol:
so we appear to have settled on every body having their favourite way of sharpening their plane blades, but what to do when we get them back in the body.
i have succumbed and like every body have a range of manufacturers products, some new metal planes, some really old wooden ones, and a couple of new wooden ones, not japanese. now i can sharpen the blades, i want to know the correct ways to set them.
lets start with LV, since they have the two tiny screws in the body side, do i assume that when these centre the blade within the body, the blade should be square to the throat, and the side adjuster should be central, or
will it occassionally be slightly to one side or another due to "backlash" etc???
with LN BU no side adjusters, so whats the best way,
also on my block plane, the adjustment in the blade for backward and forward movement is very limited, so how many times and how far can you sharpen before you need a new blade because it can no longer reach the throat??
side adjustment for clifton no 5 same applies as to LV i guess, should side adjuster be vertical?
complaint about particularly the clifton adjusting the frog screws is a pain in the butt, there really should be an angled screwdriver with a wide blade available. what do others use? the LV is better as is LN.
finally i have a couple or so older wooden planes and whilst i understand shoving the wedge in, how do you easily adjust the blade without moving the wedge to much? my newer ones have a metal stud at rear, what is that for and how do you adjust it??
i have read a couple of articles including the most recent by DC about setting the blades, but just thought to find out more info. particularly for the wooden planes. obviously the ECE are relatively easy since the have adjusters but hitting the flaming thing, thats a long stretch no??? :wink:
anyway so far my metal planes all give me thin shavings, but need to be sure i am right again
paul
paul
