Victorthesecond
Hello everyone. We have a converted garage (with bathroom) that is used when we have all of our family visit and is used as a bedroom - in the space (other than the bathroom) there is a sofa bed. The room isn't used for anything else, so has become somewhere to dump stuff and I'm keen to make better use of it!
What I am planning is to build a workbench in a sort of frame around the sofa bed. The sofa bed will be protected from dust etc by a good quality plastic cover that will go over the whole thing. Effectively, the workbench will go across the seating area / arms of the settee - the back of the sofa bed will still be visible but, as I say, will be protected from dust. There shouldn't be any risk of damage to the back of the sofa bed as all the work will be done at the front of the bench. I could always place a wooden back to the top of the bench to ensure no damage to the sofa bed.
My plan is that the actual bench will be a simple affair with 2 "H" frames at each end. These will be connected lengthways to give some stability, and there will be a centre piece connecting the front to the rear. The top will be 2 pieces of solid MDF (which I already have) and which will rest on the framework, supported in the middle (ie at each end of the 2 pieces of MDF) and by each of the "H" frames.
I need to make it easy to dismantle when the room needs to be used (that is perhaps only a few weeks each year). (I'm not sure where the dismantled parts will be stored yet but will find space somewhere!)
Hopefully, the rather rough picture attached will show this plan! The width (i.e side to side) is 2m, the depth (front to back) is 700mm and the height will be 1m.
I think I can just "drop" the MDF onto the frame and simply insert coach bolts through the MDF into corresponding holes in the top of each upright (also , I think, on the centre support) and that will hold the top in place. The coach bolt heads will be sunk into the MDF. Coach bolts supporting the centre can easily be secured by using a bolt to go all the way through the supporting lengths and using a wing nut underneath. It doesn't, I don't think, need to any more securely attached - this isn't going to be used for any heavy duty work but much more as a) simply somewhere to keep tools handy and b) somewhere to work on for modest projects. So, the bolts at each corner will simply act as sort of pegs.... There won't be a vice or anything like that attached.
I'm also thinking that I can attach each "H" to the supporting (front and rear) lengths by inserting a coach bolt into each "H", drill a corresponding hole into the ends of the supporting lengths for the coach bolt to pass through, and then drill out a hole (underneath each supporting length) that is big enough to let me insert a wing nut and screw it onto the coach bolt.
I'd appreciate any other ideas! Also, I think I can use 4x2 lengths of timber for each "H" and all the supporting material, but am happy to be guided if you think differently....
Thank you in advance of any ideas!
Mike
Mike
