accipiter
Hi everyone. I'm aware that quite a bit of what I'm about to mention/ask about has more than likely been covered some time in the past - and/or in YT vids - so I give apologies now for going over old ground. I'd like to make this a short post for help but can't see that happening because of trying to provide as much information as I can, for you, to cover where I'm at at this moment which has brought me to post. Please bear with me
I'm about to (have to) make up a *portable* router table top as I have some small (thin) bits to work on and they can't be done either stuck down with double sided tape or held in some type of clamping device - i.e. workmate of similar - I also have a use for the router table for other woodworking so this is not *just* for these items.
Until now I've managed to use a Lidls/Parkside router table by adapting the bases - making an insert - on two old 1/4" routers, namely an old B&D (40-45 years old?) and an Elu 96 (30'ish years old) and a "scissor lift" as a raiser. The Parkside router table is for routers with bases *up to 155mm* - I've put that in bold because of coming across a very old thread re that size of base dating back to 2010 which caused a bit of a stir - and that's 11 years ago and I'm not wanting to create the same again...
Sadly I can no longer use these two old routers because they died on me a few days ago which is why I'm now having to look at making something with the Rockler Phenolic Router Plate for Non-Triton Routers 1-1/2'' x 4'' 910661 I purchased from Yandle's 11 months ago - knowing at some point I'd be making a router table when I got to sort out the workshop. Trying to find a router with a 155mm base is not easy so I'm at something of a loss regarding what to do with the table - although I'm waiting to hear from the manufacturer/supplier re routers/base 155mm...
Because these old two routers died I went looking for replacements and bought a Trend T7 1/2" 2100W variable speed from Toolstation and also a Bosch POF 1200 AE 1/4" from Axminster because of the *acceptable* prices of £149.99 and £66.98... and I couldn't find any mentions of base plate sizes on ANY routers I looked at. Probably wrong in buying these two because of the base sizes being (approx.) 165mm and 171mm but as I'm attempting to fit one/either one to the base plate from Yandle's I wasn't viewing the purchases as such *for the existing table* when buying.
Now I'm preparing the top for inserting the plate I'm not so sure because a/ the Bosch 1200 AE has an auto locking clamp which has to be depressed to 'release' so you can plunge and b/ the screws that attach the base plates to the routers are not long enough for me to re-use to attach the router/s to the Rockler plate... and I don't know (haven't been able to find out) what the threads are on these. The plate is approx. 3/8" - 9.5mm? - thick. The screws for the router base plates are approx. 1/4"~3/8". Any one know these threads - or where I can get that information from please? I *have* marked out the router base plates shapes and screw positions on the insert but not yet drilled for mounting the router/s OR cut out for inserting the plate in to the selected top: 24mm MRMDF.
I'm tending towards using the Bosch 1200 AE because I've been able to find a "lift retrofit kit for Bosch POF 1400 ACE 1200 AE" for raising/lowering the router - - - but unsure IF I have to remove or somehow disable the "auto locking clamp" and/or remove one or both springs??? The same applies with regards to the Trend T7 regarding the springs but the "clamping trigger" is different as *you* have to apply it to lock depth unlike with the Bosch and I've yet to sort a lift mechanism for it.
So, I guess, basically, the questions/assistance I'm looking for are in respect of;
1/ where can I find longer screws of the correct thread for fixing the base/s to the Rockler plate
2/ can anyone advise if I need to - and how to - disable the "Auto Locking Clamp" on the Bosch and if I remove one or both - if any - plunge springs in the "arms"
3/ IF using the T7 do I remove the springs - one or both? - and ideas for a lift system
4/ Anyone able to tell me of a router WITH a 155mm base plate - so I can still make use of the Parkside router table
And 5/... * for metal workers* mostly - if no 155mm base routers known of "is it possible to alter the base plate insert area of this existing table - - - it's cast steel I think(???) - I wouldn't be attempting this myself but possibly a local metal works place. I've yet to ask them as I've only just thought of this one
Hopefully I've provided ALL information for members to be able to offer assistance - if I haven't put those reading to the end to sleep Thanks ALL for your time
