I thank you for all the input. Now for the explanation of my intentions - first, in my country materials like Compacmel are not available, same goes for MR MDF. Our market of boards is retard, you can find what sells and non-standard materials (which in the UK are pretty standard) might be available on order basis provided you purchase a whole pallet which costs thousands of EUR.
I'd be interested in knowing how you get on.
Will make a post out of the build as soon as I have all details worked out. It will have some pretty interesting features, the best in several 'worlds'. Or so I imagine it, remains to be seen if I can pull it through.
Below is a representation of my workbench, just to get an idea. Basically it is a workbench built according to some plans I purchased and with the top 'borrowed' from Hooked on Wood's 'Ultimate Workbench'
Building your ultimate workbench
What is your reasoning behing using the HPL ?
It all started with me finding out that the top of the JessEm Mast-R-Lift Excel (which has been my dream setup for many years - until I decided to betray and switch to Incra), as well as other router table tops and some of the quality insert plates are made of HPL. I am in a difficult market and country striving to put together a workshop for the hobbyist aspiring woodworker in a place that doesn't have this concept. So my options are terribly limited. I've also burned through my budget buying tools and machines from the UK and other places of the world. This is just to give a bit of context, not complaining. I managed to get my paws on a few boards of 12mm HPL from second-hand office furniture. HPL is so expensive here that we have a flourishing market of used HPL furniture.
Long story short, I want to use HPL for the router section. It's a Triton TRA001 on the corresponding Incra Magnalock insert plate and I want to know it's sturdy and solid even if that bench section will have reinforcements below.
I thought (or better said didn't think it through) and acted on impulse buying HPL boards to cover the entire bench in the idea that I would get a solid and very flat surface. Because flatness is another issue here. Altough I bought quality boards from reputed sellers, nothing came flat. And I live in a low humidity area. The humidity in my shop is very low, too. I also got the boards very cheap, about £22/sq meter. Luckily I have this healthy habit of asking when I am not sure of something, hence I'm here asking you. Beyond the router section, I can use anything.
So for a top full of holes, I'd use a good mdf
And that leads me here - mdf. After all, the parf system is recommended for mdf. But what makes 'a good mdf'? As I said, no MR mdf here. We have something called '3D mdf' which they explained as being an mdf that leaves a finer finish after being machined. It's also very neat on both sides, I would say sanded although I believe it has a different finish. But it feels like having been sanded to #1200. And it leaves a perfect edge after being cut or routed. Other than that, there is Valchromat which I can only buy in full sheets and for this size it's the equivalent of hundreds of pounds.
And than there is the famous mdf expansion issue. Or so I've been told. Maybe you can advise me in this in a few words so I understand it better.
For anything other than machine tool fences and router table tops it's not an ideal material.
I'm now thinking of leaving the router section in 12 mm HPL + 12 mm ply. For the holes section I'd like to use the approach I'm using for the rest of my benches. Mdf or plywood underside covered with 8 mm Valchromat. Some advice here will be helpful as well.
Much appreciated, sirs!
