Scrapers
lurker
Le dullard de la commune
2 Mar 2007
Leicestershire
I've been making new ones (old cheapo saw) and refurbishing existing scrapers.
I used a big cheap screwdriver to burnish them with.
However I thought I'd make proper one ( I refuse to buy such an elementary tool.
Any advice regarding Steel to use ? preferably souced free!!
I thought about the steel rod in an old inkjet printer? Anyone know what these are made of? assume SS
Thanks BB
Just what I wanted !
Will print off the referenced "how toos" when the boss is not looking!
Will run up that tool (pictured in Alf's post ) this evening.
Couldn't get around the idea I needed a long shaft of Steel
The idea of recycling an old Router bit appeals.
Lurker
You can also an old triangle file but you will have to grind the faces flat and round the corners.
I made my first one this way and still have it some where :) .
Lurker - I've made some cabinet scrapers from old saw blades and they work very well. I used to burnish them with a half round file (before I bought a proper burnisher), where the teeth end and you have smooth steel just before the handle starts. The steel from a file is about as hard as you're going to get - Rob
Colin & Woodbloke,
Strange you should say that.
When I cleared out my (deceased) Dad's workshop I found a file with all the teeth ground off.
Knowing that file steel is brittle I wondered why he had done it.
Seems I have a handled burnisher in my kit all along and did not know!!!
I really wish I had got into this woodwork thing before the old guy passed away - I've so many questions I'm sure he would have been able to answer.
Will still make the thing BB pionted out though
But yet, you bought a screwdriver (probably a flat head at that), something considerably simpler. Now I am not saying don't make your own, but the commercial ones are carefully shaped and are of the correct steel with nice handles (well the good ones anyway). Tisn't as elementary as it looks. That said, you should be able to do a very good job with any old bit of hard (harder then the scraper), smooth steel.
If anyone wants one, I have a bunch of dowel pins somewhere - I ordered one for use as a burnisher, not realising one was a packet of ?ten?. About 12mm by 50mm. Dead hard polished steel.
Yours for the price of p&p.
Tilgear carry a range of cobalt HSS (metalwork) lathe tool blanks, including round ones. Quite a bit harder than a screwdriver stem! Just right for making the burnisher in the link above. (Parting tool blanks should be about right for bespoke marking knives, too)
Burnishers do need to be hard and polished to work well.
I doubt many screwdriver shafts are up to the job.
We used to use small gudgeon pins out of engines.
Ron Hock makes a nice minimalist one without handle.
David Charlesworth
