onetruecharlatan
New member
- Joined
- 25 Sep 2006
- Messages
- 2
- Reaction score
- 0
Hi, I've owned my TS4010, (along with both extension tables and 2m sliding carriage), for about 4 years or so now, but haven't used it for more than 60 minutes running time during that period.
Why? I hear you ask.
Well, firstly space, (the usual garage with limited space).
Secondly, time. Is there ever enough of the stuff?
Thirdly, the rip fence on mine is woeful to say the least.
When either of the locking clamps are engaged, the fence furthest from the operator moves at least 3mm toward the blade. It doesn't even sit square with the table edge. When I run the fence up to the edge of the table and align the nearest part of the fence with the corner of the table, the gap at the top, (rear), end is about 4 or 5mm.
This was delivered to me in what can only be described as "kit" form, with myself having to construct the rip fence and fit the side table, (never even taken the rear table and carriage out of their packaging), as well as some other small tasks as I recall before this could be described as a working tool.
I followed the setup instructions to the letter but it's always been like this. I can't make square cuts so most of its life to date has been spent in silence.
Mine is the aluminium top model. I have read in another thread that you can buy the cast top for this table and fit it as a direct replacement. Can anyone help me with the following questions please:
1. Is this as simple a task as replacing the ali and that's that, or is there some hidden work that needs to be done by a specialist?
2. Is it just the main table that can be changed to cast, or are there options for the 2 extension tables to be replaced as well?
3. Which reseller gives the best price for these cast tops currently?
4. Even if I changed the tops for cast, as the ali ones really aren't that great, I doubt this will improve the performance of the fence, so does anyone have any suggestions on how I might have gone wrong in setting the fence/saw up and what I might do to rectify the problem?
5. Is there an aftermarket fence that will fit this saw, (cast or ali top), that preferably uses rails on both sides of the table?
I really would like to start using this saw in ernest now. I made a bed when it was first purchased and the satisfation of creating something was immense. It's just a shame that it's since been silent.
Thanking you in advance,
otc.
otc.
