scholar
Hello
This is possibly a long shot.
Does anyone have some old feed rollers from a Scheppach 260 planer?
I have a (mostly lovely) Inca planer thicknesser that is let down by the original knurled feed roller being worn. I also have a larger Scheppach planer with rubber coated feed rollers that are light years better.
A replacement Inca roller is not available, but even if it was, it would not be as good as the rubber coated rollers. I want to investigate the possibility of re-engineering some Scheppach rollers to fit the Inca. Ideally I would like to adapt some worn Scheppach ones as the diameter of the Inca rollers is I am sure smaller (I also have unresolved questions of whether the Scheppach rubber can be turned down on a lathe and the feasibility of adapting the spindles and drive cogs to fit the Inca).
I am guessing that the original Scheppach roller rubber must be machined, because the finish is very true and smooth.
Anyway, if anyone has anything lying around (or any more insight), it would be good to know!
