boysie39, as Tam says that machine pattern appears under several brand names, if it performs anything like the axminster versions then you should find it ok for at least a couple of years experience until you either get the bug hard and need to upgrade or decide to happily live with it to meet your needs.
Over here the Scheppach branding is not the cheapest.
Only caveat I would impose is that you take note of the recommendations to service the belt drive regularly, if like me with a similar first machine you use it regularly, then a once a month cleanout of the belt pulley area with the vacuum cleaner and dry-lube of the upper pulley and shaft with ptfe spray and a squirt of grease in the motor shaft for the lower pulley will keep it sweet and avoid seizing problems.
Tam, the extension arm rest is not needed for normal use, the rests reach fine without it, it just alows additional reach round a bigger bowl, albeit with a little more care on cutting loads due to the extra flex.
