Phil Pascoe
Another thing I may well do is to shorten the studs in the knobs - they are a little longer than they need be and will make their getting snagged in things more likely. It's a job for dreckly.
If your saw has four holes in a rectangle you won't need the the two straps, mine has holes on a triangle - one only at the back - so the straps bolt between the mounting bars. It's not 100% clear from the diagrams.
The pull out bars are quite sticky and benefit from being cleaned off.
