Atkins joinery
Hello everyone,
I have just come across an old draper table saw 10 inch.
It's a bit of an old nag but I was given it so I may as well tidy it up to use. I'm thinking of using it as a saw I can pop in the van to use for general work on site. The problem is, it has a 254mm blade with the centre hole bore of 16mm, most of the 254mm blades I see on the web are 30mm hole size. I have seen a couple of 16mm bore but only at a blade size of 160mm.
Can you get adaptors for saw blades to reduce bore size?
Any advice will be most appreciated.
Thanks for reading
Gareth
Sent from my GT-P5110 using Tapatalk 2
Thanks for reading
Gareth
