Save time and money with FastCap's Flush Cut Trimmers
Wood Workers Workshop
UKW Sponsor
16 Nov 2021
Threshing Barn, Upton-upon-Severn, Worcs WR8 0SN
FastCap Flush Cut Trimmers
Choose from 5 models in the Flush Cut Trimmer series to save time and money. Get the job done quickly and easily, whether you're a DIYer or a professional it's the go-to tool.
FREE UK Delivery on all orders over £75
Click here to view our festive opening hours
£23.95
Great for trimming wood and PVC edgebanding with standard thicknesses of 0.5mm - 6mm, removing nails or cutting electrical wiring, cable ties, garden plant wire and webbing.
£14.95
The tool is designed to help you remove brad nails in tight spaces. It is also ideal for trimming edgebanding and veneers, cutting cable ties and stripping wires.​
£22.96
The flush cutting head that can be used for cutting nickel or silver fret wires, edgebanding up to 3mm thick and many other applications. Great for metals like brass and copper.​
£29.95
Great for cutting nails flush, trimming welding wires and electrical cables and cutting webbing.​
£22.96
Perfect for cutting felt, leather, rubber, vinyl, PVC, Velcro, webbing, wood veneer and thin aluminium​
Paul Akers explains the FastCap Flush Cut Trimmers series
You may also like...
FastCap TracPad​
£7.96​
FastCap Screw Wax​
£7.45​
FastCap Saw Stache​
£17.95​
These actually look pretty handy, especially the end trimmer ones. Are they as strong as the Knipex piano wire cutters I normally get ?
Ollie
Ollie
Hi Ollie, the Flush Cut End Nippers are primarily designed for trimming back iron on edge banding but they are also very good at cutting back brass or copper fret wire. Sorry I have not used the Knipex piano cutters so can't compare. The HD are the strongest designed for heavier work, what they have in common is the flush cutting element.
Peter
