Saucepan disaster - is caustic soda OK on stainless?
Eric The Viking
19 Jan 2010
My better half has just burned some veg+oil in one of her new Le Creuset stainless pans.
I know caustic will remove it, but is it likely to also damage the stainless steel? It's an aluminium laminate, but the aluminium layer is inside (ss-alu-ss ply: the alu isn't visible anywhere). I know it reacts with aluminium, but I think that's not an issue in this case. Neither of us wants to scrub at it if it's not necessary, in case we damage it further.
Plan "B" is oven cleaner, but I suspect that's caustic anyway.
She's bereft: thoughts GREATLY appreciated!
E.
I'd put some hot water and Fairy washing up liquid in and leave it a few hours. Caustic and oven cleaner sounds a little harsh. alternatively if it's not moving try a dishwasher tablet and hot water, but only if theres no aluminium showing.
Gary
Variation on a theme (after Googling a bit):
1st pass: 1/2 bottle of white vinegar and bicarb (goodly heap) to about 1" depth of liquid - lots of fizzing, when that subsides, top up with water to depth. Simmer, covered, on the hob (with the fan going, as it's not a nice smell. Leave for a while, checking often and topping up the water. Can stir/work round with a wooden spoon.
2nd pass: drain, rinse, then bicarb and dishwasher powder in equal quantities, in water to similar depth as before. Simmer, working round the sides with a wooden spoon. A washing up brush is enough to lift pretty much everything at that point. There's really slight staining on the bottom still, but I'm not sure that wasn't there previously.
Definitely nicer than caustic, definitely works, definitely in her good books for a while :)
Result!
E.
Forget all of that, 1/2 cup of biological washing powder fill with warm water, leave over night, rinse, job done. Also works on stained teapots, sinks paintbrushes etc.
I keep some of the old fashioned scouring pads - wire wool with some sort of powder detergent inside - for jobs like that.
Though Scotchbrite pads work well too.
We have some Crown Merton pans made from an aluminium stainless steel sandwich (al. on the outside).
Used virtually everyday and still going strong after nearly 50yrs!
Rod
Agreed - biological washing powder is great for pans you don't want to physically scrub - works on burned on scrambled egg too :)
"Barkeeper's friend" sprinkled on a damp nylon scourer will get the residual marks off. It's also good at turning neglected old steel rules into usable ones again.
Noting the use of lemon juice or vinegar set me thinking whether you could use Coca Cola.
A quick google found the Coca Cola Method on a page about How to Clean Burnt Food from a Saucepan.
Steps to Remove the Burnt On Food:
Fill the pan with Coca-Cola.
Allow it to set in the pan for several hours, or until the food is loosened.
Use a scraper to remove as much of the residue as possible, then clean with a plastic scrubber to scrub away the rest.
Wash as usual.
Steve Maskery":1zhzwsxz said:
Andy, what is "Barkeeper's Friend" when it's at home? I've never heard of it.
S
It's a bit like Vim used to be. Sold for cleaning stainless steel. This picture is from Lakeland who say they don't have it at present but many supermarkets do.
8868_1
Just for the record though, caustic soda is fine with stainless. Most industrial pipe work and vessels containing caustic is stainless.
Barkeeper's friend is a very bad idea on any sort of stainless steel where you care about the finish - it is very abrasive and will **** it up - I've been there on my Mercury range and it cost me many many hours getting it back to looking anything like acceptable (like dismantling it and re-polishing the whole front).
Probably good for sharpening (or the inside of a pan), though.
As an aside (and risking the credibility of the entire forum): Are the pans worth the price? I liked the look of them, but SWMBO baulked at the price and got some circulon ones. A poor choice (aethetically and practically), plus they have that non-stick stuff in them that I wanted to avoid. So, are the Le C worth the wonga?
Wonga was a Christmas present from her parents. the game was up for the originals after 29 years. It's a bit hard to tell, but I think the stainless ones are a better compromise than cast iron. the heat disty isn't as good, but it's not bad still, and they seem easier to look after (we have gas). I like the design - the second handles stay cool enough so as to not need gloves usually, and they pour far better than the originals. I'm no chef, but she's a very good cook, and she likes them.
E.
Can be bad on very low quality stainless as it may contain bits n bobs which the caustic will dissolve. I know this from experience many years ago when somebody had the bright idea of removing the stains from the tea pots in the holiday camp kitchen where I worked. Lots of them sprang leaks.
Hi,
Dishwasher powder boiled is good.
We have some Cusinox pans that have a 25 year guarantee, we have had them for longer than that and they are still as good as new.
Its worth spending a little more and getting something that will last.
Similar threads
