JC800
Hi all,
I want to build my own sash windows for an Edwardian semi and not quite sure what the requirements for compliance are given my circumstances. When I bought the house upvc double glazed windows were and still are in place. I’ve salvaged a set of original sash windows from a neighbouring property which require some repairs so first question is can I get away with installing these with the necessary repairs made? If so I’d be wanting to upgrade the glass to double glazing so my second question is what would be the maximum thickness I could use given the sashes are 44mm thick?
That would be one set of circumstances, but in the event the rules won’t allow for the above option then it’s on with making my own. I am under the assumption I would not get away with like for like construction methods? So if that is the case then is there any available resource online I can seek guidance from?… I’ve done many a search but only window companies come up. Say if I wanted to use 10mm double glazed units would I need to alter the spec of the sash and casement thickness? Again, does anyone know of any available resource that stipulate the requirements for frame thickness to glazing thickness?
Thanks in advance.
Thanks in advance.
