Hi again...
I've currently reached the stage of sanding, preparatory to Plastic Coating (which, thanks Derek, seems to work great).
I started at 100 grit, then 240, 320, 400, 600, 1000, 1200 (!), mixing glass, aluminium, wet & dry (used dry) types as they came to hand. On the walnut that makes the surface smooth as silk. On a pale wood, though, (tulipwood), it's nice & smooth but the dark-coloured finer grit sticks in the grain after 1000 & makes it look grimy & horrible.
Should I have stuck with glasspaper only? Would that still leave an infestation, only light-coloured?
Now I've gone back to 240, trying to make it look clean again, not fully successfully.
No doubt the same thing happened to the walnut, only it didn't show so much.
Who'd have thunk there was so much to learn?
Any comments/advice please?
Thanks,
Graham
Thanks,
Graham
