Sand blasting wood
AndyBoyd
22 Nov 2002
Heiloo The Netherlands
I've always been tempted to create that weather beaten effect on wood and make some cabinets from it (deep grain wear rounding edges etc.), I read Sam Maloof did this using a sand blaster.
Now this got me wondering how to sand blast, now I have a power washer surely I could rig up some extra venturi effect type of fitting onto that, as the water passes through would pick up the sand - ?
Any thoughts/experience anyone?
Here's hoping
Andy,
It sounds hugely messy. Have you considered a brass brush on a drill - quite effective for "digging out" the softer bits and leaving a weatherbeaten surface.
maybe i am getting old( yeh alright :lol: i am , but)
i have a badger modellers sand blaster which came in under 40 quid i seem to remember. not sure if they still do them, but basically it was an adaptation of their 250/8 model. so my thought is it might be possible to buy a very cheap airbrush like the badger 250/4, and run the hole wide open, without the needle, and then the only problem is getting fine enough
grit/sand.
remember though that the finish will be somewhat dull.
paul :wink:
Currently on the Tilgear winter offers flyer for £29.50 +VAT :D
Hi Andy,
I used one on my power washer it was a "lavor" petrol model and the attachment was about £30 bayonet fitting.Yes it worked but lots of water about!
I've got one for the compressor now from also from machinemart just like a spray gun but bigger hardened ,replaceable nozzle and i just use kiln dried sand from diy chain.Thats the sand for brushing into block paving :) .
Pipe makers - (that is smoking pipes) often sandblast a briar pipe that has imperfections.
Different effects can be achieved depending on how aggressive the approach. I think Dunhill used to do a sandblast called "shilling" as the grain in the briar resembled rings like a stack of shillings. 8)
Look at this example of a sandblast effect on a Tokutomi blowfish;
http://www.smokingpipes.com/pipes/new/tokutomi/moreinfo.cfm?Product_ID=5431
I like pipes. :D
Esc.
Thanks every one - lots to think about, I also have a wall which needs sand blasting to clean it so I am trying to cover two things with one tool. Seems the Machine Mart addition may be the way to go.
