Thank you.
I thought about epoxy on the side, but I reckon I'll just file my way through it quite quickly and then damage the sides of the slot.
To give some background, I am looking to cut reasonably accurate rectangular and long trapezium-shaped slots in thin aluminium (3-6mm) and brass(3mm) and need a very fine end finish. The slot size accuracy does not have to be engineering-grade precise - an error of +/-0.3mm is very acceptable and even +/- 0.5mm, while not ideal, won't be a show stopper. The sides have to be dead straight.
I have zero metalworking experience though
. But I have two hands & two eyes which I hope should prove sufficient for the job after a bit of practice.
An idea of getting a mini mill like the Axi SX1 that's currently on discount has crossed my mind, but the mill won't leave a square corner, would it. So I'll need to hand-finish the ends of the slots. And, without proper tooling this will ruin the milled surface on the long edges.
Laser cutting makes a pig's ear out of the edges and is only suitable for the initial rough hogging out of the material. Same can be achieved with 2 drill holes and a jeweller's saw.
CNC machining comes back with astronomical quotes for what I need.
CNC punching I have never used, but I expect the finish and accuracy will be sub-standard and I'll need to hand-finish. This is cheap though, so can be a viable option for roughing the blanks.
So while I have a good choice of roughing out (where a Neanderthal approach of drilling, sawing and filing is not miles behind any hi-tech options tbh), the final shaping seems to come down to a set of safety hand files and Mk1 eyeball.
Am I too daft to think that 15 minutes on a flat surface with sandpaper & some elbow grease will reduce the smooth cut of a file's back to nothing? A cheapo diamond honing plate maybe? Or is it an hour's worth of work per file & a ruined diamond plate?
I can also put some sandpaper on the Axi drum sander thingiemajig for the pillar drill, clamp a fence next to it and use it as an improvised mini-thickness sander drum...
Basically, I am completely out of my depth here, so I'd welcome any suggestions.
