I had a similar question for a crib I’m building and I’ve been trying to read up on finishes for this purpose.I have built a hardwood rocking cradle, is there a safe wood stain to use given its proposed use, or will any do? It will be clear stain
Ta,
I read that about curedfinishes too, will probably try some danish oil i have lying around - french polish seems to much like hard work.I had a similar question for a crib I’m building and I’ve been trying to read up on finishes for this purpose.
One take from a book I was reading suggests that all finishes are food/toy/baby safe once cured. Which opens a lot of doors for you.
If you’re playing it really safe from my reading shellac (derived from beetles) would be perfectly safe as they use it in cosmetics and the food industry. The alcohol evaporates quickly and cure time is very short. Food safe wax can be added over the top.
That’s what I’m planning to use, the shellac comes in different colours (shades of amber / brown) dependent on what beetles they grind up to make it. It gives an extra element of colour to the wood and film of protection. You can get transparent also.
There’s the French polish application method (I’ve never done it before, not sure if I will apply to the crib for my first go) or looks like if you thin it down you can apply with a brush.
Alternatively mineral oil is a popular suggestion.
I’m sure it won’t be a problem but American standards are different ( that magazine article appears to be from there) quite a few food colourings used there wouldn’t pass European standards for instance.I had a similar question for a crib I’m building and I’ve been trying to read up on finishes for this purpose.
Do you really want to stain it - if so the question is why ? The occupant won't notice !! For furniture like this with multiple components it's better to give ti a good hardwearing finish. I would spray it to make life easier. The Chestnut range of lacquers are excellent. Heat them in a can of hot water first and use one of those spray handles for cans - it will be too hot to hold anyway. Allow a few days to completely harden off.I have built a hardwood rocking cradle, is there a safe wood stain to use given its proposed use, or will any do? It will be clear stain
Ta,
Good shout, might try that. Sanded down the finish of the meranti and ply look good as they are.Do you really want to stain it - if so the question is why ? The occupant won't notice !! For furniture like this with multiple components it's better to give ti a good hardwearing finish. I would spray it to make life easier. The Chestnut range of lacquers are excellent. Heat them in a can of hot water first and use one of those spray handles for cans - it will be too hot to hold anyway. Allow a few days to completely harden off.
