I have posted this request in general woodworking but i think it would of been better placed here
My Ryobi ETS 1825 Table saw when i start up some times makes an awful chattering sound and the speed fluctuates slow and fast sometimes it settles down and runs normal as it doe's sometimes from the start , I have replaced the brushes and cleaned the rotor with wet and dry i scraped the insulation between the copper segments i dont know if i did it enough should it be slightly below the circumference of the rotor leaving a small air gap between the copper segments or level with them , The saw is fitted with a soft start system could this unit be faulty causing the problem any help would be appreciated Thingybob
