Inspired by others on the forum, plus a chronic shortage of space, I've finally got round to modifying my SIP T/S saw to take my router. The Fence is at the design stage and will, hopefully follow tomorrow.
Then there's the over head router to follow!
This is the top with the router mounting holes drilled.
Here the view of the underside after machining.
The router complete with dust shield and lit mechanism ready for mounting in position.
And here mounted in position and the table saw extension bolted on to the T/S.
This is the router NVR switch and speed control attached to the T/S leg. I wired the assembly into the input of the T/S NVR so as to ensure that only one lead power was was required.
The view from above showing the height adjuster handle in use.
Roy.
Roy.
